Normalize
WeirDave
Normalize
Post by WeirDave » Sat Oct 26, 2013 4:35 pm
If I record an entire side of a 12" does it make a difference if I divide the track up with labels before I run normalize or is it the same regardless?
WeirDave
waxcylinder
Re: Normalize
Post by waxcylinder » Sun Oct 27, 2013 11:45 am
It's the same regardless - provided you select the whole recording, rather than individual songs, to Normalize.
waxcylinder
Re: Normalize
Post by waxcylinder » Sun Oct 27, 2013 11:47 am
I tend to add my labels while the LP is recording (this is somewhat of an advanced rechnique but it saves me a lot of time).
But you have to be careful that focus remains on the label and label track as you do that as otherwise keystrokes can be interpreted as keyboard shortcuts and operate on the recording - most importantly "space" can stop the recording - don't ask me how I know :roll:
WeirDave
Re: Normalize
Post by WeirDave » Mon Oct 28, 2013 12:37 pm
waxcylinder wrote:It's the same regardless - provided you select the whole recording, rather than individual songs, to Normalize.
Thank you!
