Audacity 2.0.3 online manual
sailorsteve
Post by sailorsteve » Tue Oct 22, 2013 9:25 pm
Working with Audacity 2.0.3 yesterday and today because 2.0.4 kept crashing my computer. Vista 64 bit OS. Now I can't seem to get back to the online version of the 2.0.3 manual and the local version (in my computer) does not seem to be working properly. Do I have to start over with the 2.5.0?
Re: Audacity 2.0.3 online manual
Post by Gale Andrews » Tue Oct 22, 2013 10:22 pm
sailorsteve wrote:Working with Audacity 2.0.3 yesterday and today because 2.0.4 kept crashing my computer. Vista 64 bit OS.
If Audacity 2.0.4 crashed as soon as you tried to start it, this was probably due to its Windows WDM-KS audio host support. If so, WDM-KS has been removed from 2.0.5, so updating to 2.0.5 will cure the problem. Please visit http://audacityteam.org/download/windows .
sailorsteve wrote:Now I can't seem to get back to the online version of the 2.0.3 manual
This is expected. The online Manual is for the current release, so yesterday it showed the 2.0.4 Manual.
sailorsteve wrote:the local version (in my computer) does not seem to be working properly
Perhaps the pages have been modified somehow. If you upgrade to 2.0.5 as above, installing using the EXE installer, this should solve the crash and the problem with the local Manual.
sailorsteve
Post by sailorsteve » Wed Oct 23, 2013 12:55 pm
Thank you for your help. I've installed 2.0.5 and deleted the earlier versions, will be able to try it tomorrow. Are there any basic differences between the old and new versions I need to know when recording LP's?
Post by steve » Wed Oct 23, 2013 1:34 pm
sailorsteve wrote:Thank you for your help. I've installed 2.0.5 and deleted the earlier versions, will be able to try it tomorrow. Are there any basic differences between the old and new versions I need to know when recording LP's?
Mostly bug fixes. I don't think there's much that will affect you, but the changes are outlined in the release notes (see: http://wiki.audacityteam.org/wiki/Release_Notes_2.0.5)
