Can edit and listen to music but not record?
VenusAndMars
Post by VenusAndMars » Sun Oct 06, 2013 9:18 pm
I have an ASUS desktop and playback of sound but I cannot use the record jack I use Audacity for sound editing and everything works fine but when I try to record, I get
Why is that do you think?
Thanks.
Win 7 Ultimate
Audacity 2.0.3
.exe installer
Re: Can edit and listen to music but not record?
Post by kozikowski » Sun Oct 06, 2013 10:44 pm
Audacity is calling for sound specifications that your sound device can't deliver. Are you using the pink Mic-In in the side of your machine?
http://www.kozco.com/tech/audacity/pix/ ... pSound.jpg
Are you using it for an actual microphone like this..
http://kozco.com/tech/audacity/pix/comp ... ophone.jpg
You should try 44100, 16-bit, Mono for a single microphone. Some computers configure the microphone to appear on both sides of a stereo show, so you can try Stereo in that setting.
Audacity > Edit > Preferences > Devices
Audacity > Edit > Preferences > Quality
Also:
http://manual.audacityteam.org/o/man/fa ... und_device
VenusAndMars
Post by VenusAndMars » Mon Oct 07, 2013 12:26 am
Thanks for the reply. My question was really about Audacity. Shouldn't I be able to record, regardless of everything else. The Realtek Audio driver is up-to date.
As you can see Audacity senses no input device although it is of course there. Speakers/output are sensed and presented correctly and all devices are enabled.
Post by steve » Mon Oct 07, 2013 1:05 am
VenusAndMars wrote:Speakers/output are sensed and presented correctly and all devices are enabled.
They are not "fully" enabled - They are not available because (according to Windows) nothing is plugged in, so Windows is not making them available to Audacity.
VenusAndMars
Post by VenusAndMars » Mon Oct 07, 2013 1:12 am
So you're saying the physical connection between record jack and sound card (or rather lack thereof) is what's the problem? Sounds absolutely plausible to me.
Post by Gale Andrews » Mon Oct 07, 2013 2:49 am
What input do you want to record from? Yourself speaking into an internal microphone?
Do you have an external microphone that comes with a cable, or a cable that is connected to a pre-amplified signal such as from a record player?
Or are you trying to record sounds that the computer is playing?
In your picture of Windows, try right-clicking over empty space and if "Show Disabled Devices" is not checked (not ticked), click it to add a check mark then post another image.
Post by Gale Andrews » Mon Oct 07, 2013 3:38 am
Gale Andrews wrote:In your picture of Windows, try right-clicking over empty space and if "Show Disabled Devices" is not checked (not ticked), click it to add a check mark then post another image.
Also right-click over each device and choose "Enable" if you see that - I think those devices could be disabled as well as not plugged in.
VenusAndMars
Post by VenusAndMars » Mon Oct 07, 2013 6:09 am
"What input do you want to record from? Yourself speaking into an internal microphone?"
That or what's playing right then through the speakers.
"Do you have an external microphone that comes with a cable, or a cable that is connected to a pre-amplified signal such as from a record player? "
Headset type thing - no amplification
"Or are you trying to record sounds that the computer is playing?"
See above, yeah sure
"In your picture of Windows, try right-clicking over empty space and if "Show Disabled Devices" is not checked (not ticked), click it to add a check mark then post another image."
This I don't get. My picture of Windows? Like I think I said before all recording devices are enabled
VenusAndMars
Post by VenusAndMars » Mon Oct 07, 2013 6:13 am
Nope, enabled. That's the thing that makes it look like it's a case of a connector not being connected
Post by steve » Mon Oct 07, 2013 9:28 am
VenusAndMars wrote:"Or are you trying to record sounds that the computer is playing?"
To record sounds that are playing through the computer you need to select "Stereo Mix" as the recording input. However, many Windows computers do not have that option. Your computer does not have that option, as is evident here:
As you don't have that option you will need to use some other method. See here for some suggestions:
http://wiki.audacityteam.org/wiki/Mixer ... _Issues#cp
To record from a microphone, you need to have a microphone plugged in.
To record from the "Line in", you need to have something plugged into the line input.
