If I select WASAPI, the microphone option, instead of showing the microphone in the drop-down, shows "Earphones (loopback)" and doesn't record. Directsound allows me to record as before in version 2.0.3.
Any ideas?
2.0.4 Can't Record using WASAPI
Re: 2.0.4 Can't Record using WASAPI
Use Direct Sound?hurra03 wrote:If I select WASAPI, the microphone option, instead of showing the microphone in the drop-down, shows "Earphones (loopback)" and doesn't record. Directsound allows me to record as before in version 2.0.3.
Any ideas?
- Quality Assurance
The WASAPI implementation is currently only for recording computer playback, as described in the Release Notes: http://wiki.audacityteam.org/wiki/Relea ... _Recording .hurra03 wrote:If I select WASAPI, the microphone option, instead of showing the microphone in the drop-down, shows "Earphones (loopback)" and doesn't record. Directsound allows me to record as before in version 2.0.3.
You can use MME or Windows DirectSound as before, or you can try Windows WDM-KS (see the link above for details).
