change dither to none? in quality settings?
Re: change dither to none? in quality settings?
Post by Gale Andrews » Sat Sep 07, 2013 11:25 am
Just to round this off, there will not be a fix for this in 2.0.4 (which is now released ) .
The problem goes back seven years, apparently and it was not felt the release should be held up for finalising the fix and having another "release candidate" testing period.
