change dither to none? in quality settings?
bomber1978
Re: change dither to none? in quality settings?
I don't know how to explain more clearly than I already have...
And I've just had the same happen with a completely different file....
Open the original 16bit/44.1 file.
Highlight the file with the cursor and increase speed +0.1%, go to export and select FLAC..
Dither is SHAPED.
Repeat this except on export save as WAV...
Both exported WAV and FLAC are 16bit / 44.1.
WAV has louder hiss than the FLAC in the silence before the music....
I can hear it in the 3 different programmes I listened with....
Dither is SHAPED.
How? Drag it into an open project? Open Audacity and select "File > Import > Audio"? Some other way?bomber1978 wrote:Open the original 16bit/44.1 file.
When the audio has been imported, in the panel on the left side of the track, does it say that it is 16 bit, 24 bit or 32 bit float?
Is it a mono or stereo track?
How? Using the Change Speed effect? or the Transcription Toolbar? or the "Sliding Time Scale / Pitch Shift" effect? Some other way?bomber1978 wrote:and increase speed +0.1%
What file name are you entering? Is it a new unique file name or are you overwriting an existing file?bomber1978 wrote:go to export and select FLAC..
That's in "Edit > Preferences > Quality" ?bomber1978 wrote:Dither is SHAPED.
With the same file that you imported in step 1? (what was "step 1"?)bomber1978 wrote:Repeat this except on export save as WAV...
When played how? In what program?bomber1978 wrote:WAV has louder hiss than the FLAC in the silence before the music....
If you import the files back into Audacity, do they sound the same?
What programs?bomber1978 wrote:I can hear it in the 3 different programmes I listened with....
I can't see your computer or what you are pressing, so "step by step" really does need to be click by click and key by key if I am to be able to reproduce the same result.
bomber1978
*Open Audacity - File - Open - Double click track
Left panel says Stereo 32 bit float.
*Highlight track with cursor from right to left - select Effect - Change speed - in box make % change 0.1 and standard vinyl RPM n/a and n/a, click OK and speed changes....
*File - Export (doesn't matter what name you make it same results, even if you leave the original name and just add.wav) eg. I just used the name "+0.1 increase.wav", then click save, file will save....
*yes Dither is still set to Shaped in Edit - Preferences - Quality.
Repeat exactly as above but save as FLAC not WAV. Both outputs are definitely 2stereo 16bit/44.1.
Playback in Audacity, Adobe Audition 1.5 and GoldWave all have the louder hiss in the WAV.
Try this:
1) Open Audacity.
2) Generate menu > Silence. Generate 6 seconds of silence.
3) Export as silence1.flac (Click the "Options" button to ensure that the FLAC exporter is set to 16 bit).
4) Export as silence2.wav (16 bit Microsoft PCM WAV)
5) Play the exported files - do you hear a difference in the amount of hiss?
6) Close and restart Audacity.
7) Import silence1.flac and silence2.wav into Audacity.
8) Ctrl+A (select all)
9) Effect > Amplify. Apply the "Amplify" effect with the default settings.
Do both tracks show the same amount of noise?
1) Open Audacity.
bomber1978
Hi,
Going through the process you listed produces 2 files which seem to have the same amount of hiss to me...., the WAV and FLAC seem to be the same...
However I just downloaded Audacity on a completely different computer (PC not my laptop), and doing the exact process' I have previously described
also produced the WAV with more hiss than the FLAC.
I have notcied the hiss in the WAV doesn't seem quite as loud on the PC as my laptop, it's definitely quiter on the PC, however still more than the FLAC, I then transferred the files made on my PC to my laptop and when played on my laptop the hiss in the WAV produced on my PC is exactly as loud as the WAV produced on my laptop, so the loudness of the hiss seems different whether played on my laptop or PC, however on both PC and laptop the WAV hiss is still louder than the FLAC.
I'm listening full volume with earphones...
Here's the first 3 seconds of the FLAC:
http://www.4shared.com/file/eyy4msHP/01 ... _SHAP.html
Here's the first 3 seconds of the WAV:
http://www.4shared.com/music/JW_0dyqh/0 ... d_SHA.html
So it's over to you. Tell me how to reproduce the difference that you are hearing,bomber1978 wrote:Going through the process you listed produces 2 files which seem to have the same amount of hiss to me...., the WAV and FLAC seem to be the same...
If it requires importing a file, please upload that file somewhere on the Internet so that I can download it and reproduce your results.
bomber1978
Hi,
The process is as I posted 2 posts ago, I think I have included every detail....
I got the same results with 2 other songs I saved from an album, seems to be that as long as there is silence before the track the WAV will have louder hiss...
For example, it happens with this original file:
http://www.sendspace.com/file/xxwkqs
I don't have an account with 4shared but it won't let me download the file without.
Could you upload the file somewhere that registering is not required (for example sendspace.com) or alternatively is it possible to reproduce the problem using generated tones?
bomber1978
Hi,
I've replaced the link with a SendSpace link.
Thanks. Got it.bomber1978 wrote:I've replaced the link with a SendSpace link.
Steps:
- Launch Audacity (new project)
- Preferences > Quality:
Default sample rate: 44100
Default sample format: 32 bit float
High quality conversion: High quality / shaped. - Preferences > Import export:
Read uncompressed directly ... (faster) - File > Import > Audio: The Cure - 01 - Pictures of You.flac
- Ctrl+A (select all)
- Effect > Change Speed: Percent change = 0.1
- File > Export: File format Flac (16 bit, level 5), Name: "flack-test"
- File > Export: File format WAV (Microsoft PCM signed 16 bit), Name: "wav-test"
- File > Close: Save Changes = No (Project closes and a new project window opens.
- File > Import > Audio: Select "flac-test.flac" and "wav-test.wav" (the two files are imported).
- Select the first 2 seconds in both tracks.
- Ctrl+T (trim)
- Select the flac-test track and "Export Selection" as: File type: other uncompressed format, WAV (Microsoft), 32 bit float, name: "flack-test-export.wav"
- Select the wav-test track and "Export Selection" as: File type: other uncompressed format, WAV (Microsoft), 32 bit float, name: "wav-test-export.wav"
(32 bit float export is bit for bit identical to the data in the Audacity project).
So what did I do different? How do I reproduce your results?
