I'm running Audacity 2.0.0 on Windows 7 Ultimate (64 bit, SP1) and trying to play a labeled section.
After creating a labeled section, I can click inside the label which selects the section. At that point, "export selection" works as expected.
But trying to play the selected labeled section with the space bar just adds spaces into the label. I can play the selection with the "play" and "stop" buttons on the transport, though.
Am I missing anything here? Thanks....Lyle
playing a labeled selection
Robert J. H.
Re: playing a labeled selection
You are in the Label text edit mode.
Just press enter to leave it. Space bar or play in general will now work.
You can also assign an alternative key combination to play (in preferences).
It must be a combination that does not represent a character or number. My assignement is for example Ctrl-Space. This will not alter the behaviour of the space key - it will still work to play and stop tracks.
Additionally, you can navigate between the labels by pressing Tab and Shift-Tab and play them with the new key assignement.
Thanks, Robert. Got it.....Lyle
Robert J. H.
You are welcome.
I guess that you now press enter before playing. Or have you tried the additional key combination too?
You can of course also click on the play button, this doesn't produce spaces either.
