getting clicks and pops from recording
kevin32
Post by kevin32 » Fri Aug 23, 2013 5:40 am
Anytime I record audio directly from a video or audio playback, the track has clicks and pops that I don't hear in the original source. Is there a way of recording so that it records exactly what I hear? Thanks.
Re: getting clicks and pops from recording
Post by steve » Fri Aug 23, 2013 11:19 am
If it is something on line (Internet), see if you can download it instead. If it is a CD or DVD you can probably "rip it" (digitally extract). If it is copy protected, you probably shouldn't be copying it.
Fabbelle
Operating System: Windows 7
Post by Fabbelle » Sat Aug 24, 2013 9:46 am
Do you mean you hear these clicks after you have made some edits?
Because I've been making one long continuous sound from a small file, and whenever I copy and paste to make a new section, you see thick lines where the edit was made. When the audio is played back, it clicks or pops where those lines are.
When I click on the lines, it removes them and "merges" the sections together. Then the click or pop is gone.
