Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Metal96
Post
by Metal96 » Sun Aug 18, 2013 8:04 pm
Hello,
I recently purchased a new computer (or rather, built a new computer
) and went about reinstalling all my audio equipment. One of these is Audacity. However, whenever I attempt to record in Audacity, it hangs for about a minute and then tells me that there was an error opening the sound device. It does this for every sound device that isn't integrated into the motherboard (running an MSi motherboard with integrated Realtek audio). I have up-to-date drivers installed for the Audiobox 44VSL and the Virtual Audio Cable. Both are selectable from the drop-down devices list.
I am running Windows 7 x64, v. 2.0.3.
Thanks for your help!
- Quality Assurance
Post
by Gale Andrews » Sun Aug 18, 2013 11:28 pm
Thanks for helping with some of the questions recently
Have you tried everything at
http://manual.audacityteam.org/o/man/fa ... und_device ?
What host are you choosing in
Device Toolbar ? MME is the most compatible.
Have you tried Transport > Rescan Audio Devices?
Does the error occur even recording a single track into an empty project? Or are you recording overdubs?
Metal96
Post
by Metal96 » Mon Aug 19, 2013 12:16 am
I have tried everything in the manual and some googles (otherwise I wouldn't be posting
). Rescan does nothing as the devices are in the list and selectable, they just hang Audacity and then error when attempted to use. I tried both hosts, DirectSound crashed Audacity so I switched back to MME. The error occurs regardless of track material. I have noticed in my snooping in the device settings that it doesn't seem any of the devices are working at all, which is strange because they're all configurable and I've updated all the drivers (multiple times, in fact, in case of a botched install) and such. Perhaps I should not post here and move to a Windows forum...but you're probably more knowledgeable on audio stuffs
So...any ideas?
Gale Andrews wrote:Thanks for helping with some of the questions recently
You're very welcome!
- Quality Assurance
Post
by Gale Andrews » Mon Aug 19, 2013 12:27 am
Metal96 wrote:I have tried everything in the manual and some googles (otherwise I wouldn't be posting
DirectSound should not be crashing Audacity with Firebox or Virtual Audio Cable (VAC).
Metal96 wrote:I have noticed in my snooping in the device settings that it doesn't seem any of the devices are working at all, which is strange because they're all configurable and I've updated all the drivers (multiple times, in fact, in case of a botched install) and such.
Where do you see an indication that the devices are not working?
Have you tried setting Firepod or VAC as default recording device in Windows Sound, then recording with Windows Sound Recorder or some other audio program? What happens then?
Metal96 wrote: Perhaps I should not post here and move to a Windows forum
Let's see what other recording programs do.
Metal96
Post
by Metal96 » Mon Aug 19, 2013 12:34 am
The indications were that the volume meters for the devices in sound manager were blank, even when I was causing the clipping LEDs to go off on the Audiobox (also, I should note that the box is USB, not FireWire - it has no such capabilities). Also, the Audiobox VSL (it controls the DSP on the Audiobox) was not reading any audio either, nor was it outputting anything on speaker pass-through. Sound Recorder just outputs silence. For the record, I know it's not the box itself because I installed the whole shebang on a friend's laptop for testing purposes and it all works fine.
Metal96
Post
by Metal96 » Mon Aug 19, 2013 12:37 am
HOLD ON WHAT
It just started working for no reason.
Well, thanks for your help...
