The single track WAV file is 37.2MB Length:= 00:03:41DVDdoug wrote:Just something quick to check... A 44.1kHz, 16-bit, stereo file (CD format) is about 10MB per minute. If your file is much smaller (or larger) than that, it's probably not a regular (uncompressed PCM) WAV file.
"ZG CD Extractor"What ripping software did you use?
I have no problems playing the WAV file on my PC. (VLC, MS Media Player, etc)
If I open the WAV file in Audacity it plays perfectly too.
My apologies -- from my very raw beginer status -- I now understand I have been trying to do TWO thingsIf you have a "flat line" in Audacity, I don't understand how you can play & edit it.
- 1. Edit a CD track and save the edit as an MP3 file for a android phone "notification"
. . . Now resolved by ripping the CD track to a WAV file -> Open in Audacity -> Edit in Audacity -> Save the result as an MP3 file
2. Capture/record an audio source (ie, record a YouTube audio)
. . . I have been playing the WAV file as a virtual audio source, a mistake on my part, now that I know Audacity captures nothing.
. . . I am still lost on this one ... how to record an internet-YouTube audio ?
I now understand the difference -- I had assumed ripping and recording were one in the same.When you open and edit a WAV file, that has nothing to do with "recording". Digitally "ripping" is NOT "recording" either.
... would I need such a program to record internet audio in Audacity?A program like Total Recorder should be good for recording "analog" signals
If so how would I tell Audacity that "Total Recorder" is the source, because at the moment Audacity does not detect any internet audio source.?
Sorry about the confusion and thank you for your patience
