Tracks bleeding into new tracks
shanedurgee
Post by shanedurgee » Mon Aug 05, 2013 8:18 pm
This topic seems to come up occasionally, but there's nothing on the forum that solves my particular problem.
I have a Dell N5110 with an IDT High Definition Sound Card. Windows 7.
I'm using a microphone in the line in jack and headphone (NOT USB) in the headphone jack. So both mic and headphones are plugged directly into the sound card through mini jacks on the laptop.
The drivers are up to date. The device is working properly.
The Audacity settings look fine. Input is Microphone/Line In and output is Speakers / Headphones IDT.
Under Preferences; Recording I have Overdub checked because that's the only way to hear the previous tracks while recording new ones.
My guess is that this can't be solved with this configuration/ computer, that it has something to do with the sound card and I just need to use a different computer to record music, but before I give up I thought I'd put it out here. Namely because I do not have another computer :)
I may try to use USB headphones and see if that solves it, but I'm broke and I've know idea how much those cost.
Re: Tracks bleeding into new tracks
Post by steve » Tue Aug 06, 2013 5:33 am
Just trying to get a clear picture of what is happening: Which track is bleeding into which track, and how can you tell that it is doing that?
shanedurgee
Post by shanedurgee » Tue Aug 06, 2013 4:20 pm
If I record multiple tracks, every track prior to the track I'm recording will bleed into the new track at a very low volume. So I record drums first. Then when I record guitar on a new track, you can faintly hear the drum track bleeding in. Then if I record a third, the first 2 tracks will both bleed into the new one.
Now, if it's muted I don't think it bleeds in, so it's only the tracks that I need to listen to that are appearing on the new track.
Also, I'm recording in Mono.
Post by kozikowski » Tue Aug 06, 2013 4:51 pm
There are multiple versions of this same post and we have no idea where the bleed is coming from. I wonder if we do a survey it will turn out everybody's using one particular soundcard. Koz
Post by steve » Tue Aug 06, 2013 5:06 pm
shanedurgee wrote:Then when I record guitar on a new track, you can faintly hear the drum track bleeding in.
If you play back the guitar track after recording it and have the Solo button pressed on only the guitar track, do you hear the drum track?
shanedurgee wrote:Now, if it's muted I don't think it bleeds in,
Please check that - it may be important.
It would be nice if we could rule out acoustic spill from the headphones into the microphone.
Try recording some drums, then turn down the playback volume quite low, and place the headphone in a box, under a cushion, under a pile of coats, as far from the microphone as possible (you get the idea - we're trying to prevent any possibility of sound spilling over from the headphones into the microphone). Now record some guitar (it will be out of time with the drums, but this is just a test). Now play back the guitar track with its Solo button pressed. Is there any bleed through?
shanedurgee
Post by shanedurgee » Tue Aug 06, 2013 6:18 pm
Yes. If the guitar is soloed you hear the drum track bleeding in faintly. And if more tracks are recorded you'll hear both guitar and drum tracks in those tracks, even if they're soloed.
If the drum track is muted it does not bleed in. I just tested it. I have 1 drum track and 2 guitar tracks. I had the headphones on and the microphone in my hand recording nothing in particular. Without the tracks muted, they all appeared on the new track. Then I muted them one at a time while recording until all were muted, and if you listen to the new track you can hear each previous track being muted until there was no bleed at all with all tracks muted. On the same note, it does not seem to be the headphones. The level of bleeding is consistent even with the microphone in the hallway and the headphones under a pillow.
kozikowski wrote:There are multiple versions of this same post and we have no idea where the bleed is coming from. I wonder if we do a survey it will turn out everybody's using one particular soundcard. Koz
I'm really thinking that it's the sound card. This is the factory installed sound card for a low budget laptop that is really not meant for this kind of music recording. Still, Audacity worked great on my old Dell laptop which was older and had weaker hardware.
I'm going to buy a USB headset today to change the playback output device (if I can find one for cheap). The input and output jacks are right next to each other, and I know that it shouldn't effect anything, but who knows. I'll see if that helps. Assuming that it doesn't, any other ideas?
shanedurgee
Post by shanedurgee » Tue Aug 06, 2013 6:34 pm
To be clear I did the same test with muting the tracks when the microphone was in the hall/ headphones under pillow, and had exactly the same result.
Post by kozikowski » Tue Aug 06, 2013 6:35 pm
We installed hundreds of soundcards over the years and we did find one, I think Blaster, that was a complete waste of copper and fiberglass. It was a middle model between two other cards that seemed to work ok, but this one cause no end of troubles until I identified it and we did a company-wide sweep to trash them all.
So it does happen.
Our joke was it was designed by the vacation relief guy who was only there for the summer.
shanedurgee
Post by shanedurgee » Tue Aug 06, 2013 7:10 pm
Some progress. It is related to the headphones.
I decided that I could test the headphone/output hypothesis without spending cash on USB headphones by simply putting the microphone in the next room and recording without headphones plugged in, with the output coming from the computers built in speakers. No bleed at all.
So yes, it has to do with the headphone jack and the sound card.
I'm going to try USB headphones and see what happens.
shanedurgee
Post by shanedurgee » Wed Aug 07, 2013 3:31 am
So for what its worth, the USB headphones have solved the issue.
The problem seems to be the sound card, when both mini jacks are being used. That is, when the headphones and microphone are plugged directly into this sound card there will be bleeding from the first track to the new track. Using a USB headset solved it. No bleed.
I'm not sure if using a USB mic and my regular headphones would have had the same result. I think as long as the input and output aren't both directly plugged into the sound card it'll be fine.
Thanks.
