Display value of individual sample
In Audacity 2.0.2, is it possible to display the value of an individual sample?
(One more question: is there a shortcut to view a track full-screen?)
(Windows 7 Professional, SP1)
Re: Display value of individual sample
Control-F will contract the show left to right so the whole thing fits.
Control-E will zoom into the dragged selection and Control-3 will zoom out a little bit. I live in those three.
Have a look at Sample Data Exportaudubon wrote:In Audacity 2.0.2, is it possible to display the value of an individual sample?
Thanks. I'm analyzing some audio waveforms that have certain amplitude features, and it would have been handy to be able to mouse-over or click a sample to read its value.
You can find the value of the first sample in a selection by using the Nyquist Prompt effect and running the following code:
If you want the value in dB, use this code:
You can also see an approximate value by zooming in vertically and horizontally as close in as possible
Code: Select all
(snd-fetch s)Code: Select all
(linear-to-db (abs (snd-fetch s)))9/10 questions are answered in the FREQUENTLY ASKED QUESTIONS (FAQ)
Thanks--I was able to get the data I needed by repeatedly applying the Nyquist command using ^R.
steve wrote:You can find the value of the first sample in a selection by using the Nyquist Prompt effect and running the following code:If you want the value in dB, use this code:Code: Select all
(snd-fetch s)You can also see an approximate value by zooming in vertically and horizontally as close in as possibleCode: Select all
Just out of interest, what do you need these sample values for?
Making some audio-gear measurements--attack and release times, e.g.
steve wrote:Just out of interest, what do you need these sample values for?
Sounds interesting. Good luck with your project.
