Support for ARMA2 .wss files?
quatermass
Post by quatermass » Sun Jul 28, 2013 3:21 pm
I've just started to use ARMA2 game platform to edit my missions and discovered that this game uses .wss sound files.
These will not autoload in Audacity 2.03 for Windows.
But do, if I use the import raw data option.
I've tried to use the Extended Import option to set "*.wss" to 'WAV,AIFF and other uncompressed types.'
But it never wants to directly open the .wss file with a doubleclick. I always have to use the import function.
Any way to get Audacity to just open these .wss sound files when I double click on them?
They are: Signed 16bit PCM. Litte-endian, mono, 44.1KHz WAV files.
Cheers. :D
Re: Support for ARMA2 .wss files?
Post by Gale Andrews » Sun Jul 28, 2013 10:18 pm
If these files are headerless then I don't think you can use Extended Import Preferences to force the importer.
You can I think use this command-line program to encode the WSS files to WAV:
http://ofp.gamepark.cz/utilities/OFP_WSSprogs.zip
If the WSS files have headers then please post an example somewhere.
quatermass
Post by quatermass » Mon Jul 29, 2013 9:50 pm
Just seems to have WSS0 as a header.
Here is a small sample file.
http://mytriops.com/files/fracture_1.wss
:D
Post by steve » Mon Jul 29, 2013 10:43 pm
Gale Andrews wrote:You can I think use this command-line program to encode the WSS files to WAV:
The example file can be converted with SoX if you add ".sb" to the end of the file name.
This command (for SoX) works:
Code: Select all
sox -r 44100 -b 16 -c 1 fracture_1.wss.sb fracture_1.wav
Post by Gale Andrews » Tue Jul 30, 2013 5:27 pm
quatermass wrote:Just seems to have WSS0 as a header.
Thanks, the file clearly has headers, but libsndfile (the library Audacity uses for uncompressed import) cannot understand the headers. I verified that sndfile-convert in libsndfile standalone does not understand the file.
You could write to libsndfile-devel and make a feature request about it:
http://www.mega-nerd.com/libsndfile/lists.html .
The decoder in http://ofp.gamepark.cz/utilities/OFP_WSSprogs.zip opens the WSS file without problem - you can just drop the file on "wssdec.exe".
quatermass
Post by quatermass » Fri Aug 02, 2013 8:38 am
Thanks for that. I'll get on it! :)
