Make Metadata Editor show for each multiple file [SOLVED]
sombunya
Post by sombunya » Sat Jul 20, 2013 2:46 am
Version 2.0.3 with Windows 7.
Although I've searched through the manual, I can't seem to find an answer. This will be an easy answer, I think.
In the past I'd record 5 or 6 tunes from an album side and add the metadata at each track (artist, album title, track title, track number). Then I discovered the metadata editor and saved myself lots of typing, not to mention I could copy and paste odd characters. I now open the metadata editor and add artist and album title, hit the "OK" button and then type track titles as I separate the waveform into individual tracks. They export with all the information I added . A great system I think.
However, I occasionally record compilations where every artist is different from track to track.
How can I set it so the metadata editor opens for each track, allowing me to fill in all of the fields individually for each track?
PS, I hope I was clear here. And as usual, thanks for such a great program!
Re: Metadata editor
Post by kozikowski » Sat Jul 20, 2013 3:48 am
I know this isn't going to help a lot, but Audacity launches the editor every time you export a clip. So export them one at a time instead a bunch. Koz
Re: Metadata editor
Post by Gale Andrews » Sat Jul 20, 2013 12:16 pm
sombunya wrote:How can I set it so the metadata editor opens for each track, allowing me to fill in all of the fields individually for each track?
It does that by default, assuming you are using Export Multiple. Go back to the Import / Export Preferences, put a check (tick) in "Show Metadata Editor prior to export step", then click OK.
For more information, see http://manual.audacityteam.org/o/man/me ... ditor.html .
sombunya
Re:Make Metadata Editor show for each multiple file [SOLVED]
Post by sombunya » Mon Jul 22, 2013 12:16 am
Thanks Gale. (and to you too Koz)
