I am a very new Audacity user. I just downloaded it. So here is newbie-type question. When I click on the Record button in Audacity, a box pops up saying "Error while opening sound device". I'm new to this, and I don't know what to do to solve this. Any help would be appreciated.
Thanks
Recording function
zpntenergy
- Quality Assurance
Re: Recording function
It would have helped if you had given the version of Windows and Audacity (please see the pink panel above).
I suggest you read this Frequently Asked Question:
http://manual.audacityteam.org/o/man/fa ... und_device
then if not solved, come back to us with more information including what you are trying to record.
