Is the Samson CO1U compatible with Windows 8?
Anyone know? Thanks
Re: Is the Samson CO1U compatible with Windows 8?
The older Samson mic is a straight USB sound device and should be compatible with everything. You may need to change Audacity to mono in the preferences.
