Can't import mp4 files avcodec decoder failed[SOLVED]
Re: Re:Can't import mp4 files avcodec decoder failed[SOLVED]
Post by Gale Andrews » Thu Jun 27, 2013 9:38 am
HelenWeirHypno wrote:Found a copy of a CD burning program that seemed to be using ffmpeg that I didn't use. Removed that and all is working today.
Thanks for replying that the problem was solved. I've marked it [SOLVED] and locked the topic.
