DJ Brake Effect
DJ Brake Effect
I am getting into making the music that I own clean. Is there a way to do the Brake Effect that dj's use in Audacity? If so how do I do it? Thank you for your help.
Re: DJ Brake Effect
Point to the effect on an existing sound clip.
Re: DJ Brake Effect
Ok if I am taking out explicit language on one of my tracks. The Brake effect is not in the effects tab.
- Quality Assurance
Re: DJ Brake Effect
Audacity does not ship with a "Brake Effect".DJRonnieM wrote:Ok if I am taking out explicit language on one of my tracks. The Brake effect is not in the effects tab.
If you want to try a plug-in that produces an effect like pulling the plug on a turntable, try this Nyquist plug-in http://wiki.audacityteam.org/wiki/Nyqui ... Warping_MS .
Here are instructions for installing Nyquist plug-ins http://wiki.audacityteam.org/wiki/Downl ... ns#install .
