Assume I loaded an *.mp3 song.
Now I mark a certain interval/part from the fuill length.
Can I somehow zoom into this interval?
Can I (later after editing) zoom out the the full song back again?
Peter
Zoom in (and out) into marked interval?
- Quality Assurance
Re: Zoom in (and out) into marked interval?
.pstein wrote:Assume I loaded an *.mp3 song.
View > Zoom to Selection - please see http://manual.audacityteam.org/o/man/zo ... horizontal .
In the case where you had imported the song, selected a region then done View > Zoom to Selection, yes - use View > Fit in Window.pstein wrote:Can I (later after editing) zoom out the the full song back again?
But note that View > Zoom Out would not go back to the zoom level that fits the project in the window, but to some zoom level between "selection fitted to window" and "project fitted to the window".
