No Sound Out on Second Mic
yanick
Post by yanick » Mon Jun 17, 2013 8:41 pm
Hello,
My configuration is as follows:
Tascam US-144 connected to Windows 7 PC via USB.
Running a left and right mic in via traditional 3-prong cables.
Headphones jack on Tascam running out to a simple speaker.
The current Audacity Settings are Audio Host: MME; Speakers: TASCAM US-144; Line In: TASCAM US-144; Input Channels: 2 (Stereo) Input, although I've tried just about every combination available.
The problem is this:
Both Mics appear to work when watching the gauge on the Tascam and also in Audacity; however, when I listen to recorded sound, only one Mic is heard, although both appear to be recording.
Any suggestions are greatly appreciated.
Re: No Sound Out on Second Mic
Post by kozikowski » Tue Jun 18, 2013 4:00 am
So you get two blue waves and two bouncing red sound meters like this:
http://kozco.com/tech/audacity/Audacity1_record.jpg
How are you listening? All the settings and cables.
yanick
Post by yanick » Tue Jun 18, 2013 8:44 pm
Correct.
To listen, I have a cable running from the "Phones" jack of the Tascam US-144 directly to the back of a Bluetooth speaker (It can run in Bluetooth mode, but it tends to crash when I have lots of computer stuff going on, so I just plug it in directly).
Hey! typing the above gave me a hunch, which I tried, and the issue appears to be resolved.
Thanks!
Post by steve » Tue Jun 18, 2013 10:24 pm
yanick wrote:Hey! typing the above gave me a hunch, which I tried, and the issue appears to be resolved.
Which was what?
yanick
Post by yanick » Wed Jun 19, 2013 3:30 am
Well, the line out to the headphones got me wondering whether the signal was getting blended or dumbed-down in the headphone jack. I think that's where kozikowski was headed. I don't know whether that's the case or even if it's possible, but I removed the headphone jack and just ran the Bluetooth speaker over the Bluetooth network (crashes be [email protected]) and both mics now work and the overall sound quality coming out of the speaker is much richer.
