Only Exporting the top track?
JMuth561
Post by JMuth561 » Wed Jun 12, 2013 12:10 am
I'm working with a song that I had to split into 10 different tracks and rearrange with different gain levels and effects on each track. Now that it's done, when I try to export it, it only exports the top track (the guitar part). I have tried both export and export multiple with all of the tracks highlighted, but it keeps only exporting the guitar track. Anyone know of a fix for this?
Re: Only Exporting the top track?
Post by Gale Andrews » Wed Jun 12, 2013 12:42 am
Have you muted all the tracks except the guitar track? Muted tracks are not exported.
JMuth561
Post by JMuth561 » Wed Jun 12, 2013 12:46 am
Gale Andrews wrote:Have you muted all the tracks except the guitar track? Muted tracks are not exported.
No, they're all unmuted.
Post by steve » Wed Jun 12, 2013 12:53 am
If you select all of the tracks and then apply "Tracks menu > Mix and Render", does that play OK?
