Removing voice
dissident888
Removing voice
Post by dissident888 » Fri May 31, 2013 7:32 pm
I'm trying to remove the vocals from mp3 so as to create an instrumental to use at a special occasion.
Re: Removing voice
Post by steve » Fri May 31, 2013 8:51 pm
Not wanting to sound negative, but in most cases vocal removal either does not work, or sounds dreadful. Having said that, there are some suggestions about how to attempt vocal removal here: http://wiki.audacityteam.org/wiki/Vocal_Removal
If vocal removal fails (as it probably will), have a look on Google/Amazon/etc to see if a karaoke version of the song is available for purchase.
Re: Removing voice
Post by kozikowski » Sat Jun 01, 2013 4:33 am
There is a YouTube instructional video about how to do this job in Audacity -- the hard way. The one I saw takes you carefully through all the individual steps of splitting the tracks, phase reversal, etc. etc. etc.
Effect > Vocal Removal has packaged all those steps into one tool and one pass for you.
Most songs do not lend themselves to vocal removal. This is one of mine that didn't work very well. The clip plays After and then a little Before for comparison.
http://kozco.com/tech/audacity/clips/MysteryTrain.mp3
Robert J. H.
Re: Removing voice
Post by Robert J. H. » Sat Jun 01, 2013 5:02 am
Doesn't Sound too bad Koz. The piano Comes fine up in gain.
When you sing along such a Version, your voice is sometimes able to mask all the remaining lead voice artefacts.
And when you sing as badly as I do, it will be advantageous to have sum original remaining...
Re: Removing voice
Post by kozikowski » Sat Jun 01, 2013 5:41 am
Please note the bass and drums vanished, too. This clip illustrates almost everything that can go wrong except I started with a Very High Quality Stereo original song. No compression artifacts to struggle with and no accidental mono download.
People who post these are almost always after the theatrically perfect karaoke, not a missing instrument version with the original singer in deep echo. That song is only likely to happen by writing a check to a music supplier.
We also point to the song that the teacher used. If you use that exact song, your karaoke will come out right as well. What you can't do is by extension apply this technique perfectly to all songs.
Robert J. H.
Re: Removing voice
Post by Robert J. H. » Sat Jun 01, 2013 7:28 am
You can somewhat preserve the bass with the frequency band choice.
I am not sure if the current implementation is ideal though.
It uses a filter with a roll-off of 48 dB/octave.
One Needs enough head room when applying this filter (the Output is sometimes louder than the Input).
