File Format
File Format
I'm enrolled at Devry and downloaded the software off their website, but now my professor is telling me the files I'm turning in need to be in .wav or .wma format to be accepted. So, can anyone tell me how to switch the .aup file format into either a .wav or .wma format?
Re: File Format
File menu > Export
See here for more details: http://manual.audacityteam.org/o/man/fi ... ialog.html
I'd recommend that you export in WAV format (which is the default).
