Noise when there is no waveform
jeff77789
Post by jeff77789 » Tue May 28, 2013 2:34 am
i have this .wav file that i play and even during the silences there is "noise" even though i dont see it.
i tried doing noise removal but the flat waveform doesn't give it anything of a noise profile to cancel out
if i generate silence the noise is not there but i can't seem to cancel it out
if anybody can help me cancel out the noise that would be great
jeff77789
Unseen noise?
Post by jeff77789 » Tue May 28, 2013 2:42 am
This is the .wav file i am working with:
http://dailymishaps.com/uploads/Claude% ... 20Lune.wav
when you open it up with audacity, the ends of the notes have a flat waveform but there is still noise
i tried doing noise removal but it is still there
any ideas?
Robert J. H.
Re: Unseen noise?
Post by Robert J. H. » Tue May 28, 2013 7:24 am
I sometimes use the following code to even out the Dynamics in order to make low Level noise more audible.
Try it on a copy of your track (Effects > Nyquist Prompt, paste and ok).
Code: Select all
(defun even-out (sig)
   (mult sig
         (s-max 0 (mult 1(recip (snd-avg  sig 2205 10 op-peak))))))
(multichan-expand 'even-out s)
The noise (White noise) is the most present in the beginning of the Piece - and the last note, which is horrible.
I assume that you've already used the Noise removal for this Version?
The Settings were somewhat to aggressive. A Little noise between the notes wouldn't be harmful, the decay is to abrupt for my taste.
Of courrse, I do not know what the original Piece is like.
I was able to remove some further noise by simply fetching the noise Profile of generated White noise.
But that's a very crude method.
Applying the Noise Removal twice is a very bad idea (because the artefacts increase exponentially).
Robert J. H.
Re: Noise when there is no waveform
Post by Robert J. H. » Tue May 28, 2013 7:32 am
If the silence is only in the silent parts, use a noise gate. It is much less destructive than the Noise Removal.
[Rest of message deleted because it makes no sense after Topic Joint, see post below -rjh]
Re: Unseen noise?
Post by steve » Tue May 28, 2013 9:59 am
Duplicate topic merged.
