Getting Started
humble_me_99
Getting Started
Post by humble_me_99 » Mon May 27, 2013 9:02 pm
Hi,
I really new to the software, and besides importing raw a file to audacity and attempting to play it back to see if the import process was done correctly, which it was not, I'm
stuck. Can anyone walk me through the initial steps of getting an imported file to playback. I'm using a hp windows 7 32 bit notebook. I'm attempting to learn this software
to get music ripped into windows media player, and music downloaded from the internet into my virtual dj program. It is not compatible with many music file formats. Help!
Re: Getting Started
Post by kozikowski » Mon May 27, 2013 9:13 pm
Import Raw sounds like a really cool process, but in fact it fails almost 100% of the time. So that's not a good way out.
You're going to have to nail this down a lot more for anybody's software to work. What exactly does your virtual DJ software require? Are you capturing internet songs for your shows? Were you able to get that to work?
http://manual.audacityteam.org/o/man/tu ... puter.html
You can install the FFMpeg software into your Audacity and that will Audacity to recognize and Export many more different sound formats than Audacity alone.
http://manual.audacityteam.org/index.ph ... tallffmpeg
Re: Getting Started
Post by kozikowski » Mon May 27, 2013 9:18 pm
Since you appear to be just starting out, you should know that double compressing songs isn't a very good idea because the bubbley, honking sound compression damage goes up when you do. So if you download an already ratty MP3 song and make a (for example) AAC for your Virtual DJ, the music may not sound very good. It will have all the damage of the original MP3 plus the AAC compression damage.
iTunes has a process where you can download extra quality shows at a bump in price. Those work a lot better than normal compression.
Re: Getting Started
Post by steve » Tue May 28, 2013 11:25 am
humble_me_99 wrote: Can anyone walk me through the initial steps of getting an imported file to playback
If it is a supported file type:
File menu > Import > Audio
Wait for the file to load, then click the Play button.
If the file type is not automatically recognised then we need to know what sort of file it is so that we can advise you.
