Records but no sound output
tmort
Post by tmort » Thu May 23, 2013 8:17 pm
I have a Windows 7 computer and am trying to use a USB mike. I had some problems, but, I got it to recognize the mike. I see the waveforms on record and playback, but, can't hear anything on playback. I exported the file as a wav and media player does the same. I have all the output volumes I can find set all the way up.
Re: Records but no sound output
Post by Gale Andrews » Fri May 24, 2013 6:39 am
Please see this Frequently Asked Question:
http://manual.audacityteam.org/o/man/fa ... k.html#usb .
