78 Vinyl
RobertSamuel59
78 Vinyl
Post by RobertSamuel59 » Fri May 17, 2013 4:55 pm
Dear All,
I would like to record 78 Vinyl records from my turnable, but it has only the speeds 33 and 45. In particular, I found a record of Artie Shaw in a charity shop, but don't know what to do with it. Does Audacity have the software to speed up the recording, or do I have to look elsewhere to do this?
Robert2
Re: 78 Vinyl
Post by Robert2 » Fri May 17, 2013 6:42 pm
Re: 78 Vinyl
Post by steve » Fri May 17, 2013 7:13 pm
RobertSamuel59 wrote:Does Audacity have the software to speed up the recording
Yes it does: Effect menu > Change Speed. http://manual.audacityteam.org/o/man/change_speed.html
Note that 78 records have a different groove size to 45s and 33s. Playing 78s with a "microgrove" stylus (for 33/45s) may cause permanent damage to both the record and the stylus.
waxcylinder
Re: 78 Vinyl
Post by waxcylinder » Sun May 19, 2013 3:20 pm
This workflow tutorial from the manual may be useful to you too: http://manual.audacityteam.org/o/man/re ... cords.html
