Can't mark very small segments
cartagena2001
Post by cartagena2001 » Thu May 02, 2013 6:18 pm
Hi.
I had an old version of Audacity in which I could mark very small segments of tracks. I could put the selection tool at any point I desired. Sometime ago I downloaded a new Audacity version. Now it's impossible to control the selection tool easily. It doesn't allow me to mark tiny parts of the track. it is restricted to units of seconds. How can I mark small units easily?
Thanks
Re: Can't mark very small segments
Post by steve » Thu May 02, 2013 6:21 pm
Switch off the "Snap To:" setting (it's off by default) http://manual.audacityteam.org/o/man/se ... .html#snap
