Running Audacity 2.0.3 on Windows 7. The whole menu font/point size are small. I'm not sure what changed but I don't see a away to reverse it.
The other point sizes seem OK but I'm not sure about the font. I haven't used Audacity for a couple of weeks.
Thanks for any help.
Font/point size in 2.0.3
emsteel123
Re: Font/point size in 2.0.3
On Windows 7 (and at least as far back as Win2k) menu font (size, family etc.) is controlled by Windows itself. Audacity has no control over this.
