Were can I download Audacity 1.3 to use on Win7?
- Quality Assurance
Re: Were can I download Audacity 1.3 to use on Win7?
Thanks for trying it, isrshn.
I have come to the same conclusion too. With the browser flash player and sound device on full volume (the Audacity input slider is greyed out on maximum as I think is intended) I can only record at about -15 dB peak compared to -5 dB with "stereo mix". It was uncomfortable to play what I was recording so loudly.
Robert J. H.
I've tried it too.
The Level was actually not so bad. I've no Stereo mix, hence I record directly Stereo out > line-in with a Loop cable.
At 100% Input and 80% Output, I've got:
- line-in cable (MME and WDS) 0 dB
- WASAPI -1.8 dB.
I am rather concerned about certain drop-outs during the recording.
It all starts with a pretty low latency but then a good deal is skipped.
However, I have to set the latency correction anew anyway.
At least no device error has occurred yet (except with SPDIF loopback).
Interesting new Feature though.
- WASAPI -1.8 dB.
- Quality Assurance
Robert J. H. wrote:I've tried it too.
- WASAPI -1.8 dB.
That sounds a good result. My source was an interview with music playing in the background.
It is very difficult to record any clipped input on my main Windows 7 machine even if I set a high input level, so the sound card may be intervening. However I have a common machine (HP laptop with IDT built-in sound card).
It is known that the WASAPI latency in Audacity can increase after you start recording but the main problem with that is software playthrough (and changing latency correction) as far as I know.Robert J. H. wrote:I am rather concerned about certain drop-outs during the recording.
It all starts with a pretty low latency but then a good deal is skipped. However, I have to set the latency correction anew anyway.
Did your skipping occur when you recorded from the loopback device in Device Toolbar, or from line-in? What is your Audio to Buffer setting?
Robert J. H.
The skipping occurred with the wasapi loopback from Speaker (Sound blaster x-fi xtreme Audio)
The Sound Card has a really bad latency of about 200 (-400 correction).
It is now at the Default 100/-130.
The results above are from an overdub recording.
The original recording was also done with the WASAPI but there was no skipping in the audible Sound (because I've started the recording, changed to the Flash Player and pressed Play, hence a lot of silence at the begining). But other attempts have also shown this drop-outs in direct recording. However, as I said above, I didn't bother to Change the latency yet because it is only an Alpha built.
Besides, I've noticed that the Nyquist prompt now uses another shortcut for the debug button (alt-g instead of alt-d).
Any idea where to Change that back? Was that introduced in 2.0.3 or later? I am running 2.02 at the Moment.
- Quality Assurance
Thanks. The Audio to Buffer setting is the only one that may affect skipping. If WASAPI loopback skips with Audio to Buffer on 100 ms, does it skip if you set Audio to Buffer higher, such as 200 ms?Robert J. H. wrote:The skipping occurred with the wasapi loopback from Speaker (Sound blaster x-fi xtreme Audio)
It is now at the Default 100/-130. The results above are from an overdub recording.
Rob Sykes changed it because he added a new "Defaults" button to ShuttleGui:Robert J. H. wrote:I've noticed that the Nyquist prompt now uses another shortcut for the debug button (alt-g instead of alt-d).
http://code.google.com/p/audacity/sourc ... tleGui.cpp
This change applies to the Debug button in all Nyquist effects.
However the new button isn't used anywhere yet that I know of.
Does the ALT + G conflict with something else?
Robert J. H.
Higher latency Settings fix the skipping (as expected).
The new hotkey seems not to conflict with any other plug-in.
But it is annoying when your used to alt-d for years and now you always get that nice Little ping when pressing it.
It would have been better if he had introduced a shortcut for the OK-button since enter is otherwise used in the Nyquist prompt. However, ctrl-enter works but this is nowhere documented.
- Quality Assurance
You mean higher "Audio to Buffer" settings - yes?Robert J. H. wrote:Higher latency Settings fix the skipping (as expected).
If you want to, could you choose Windows WASAPI host, choose the line-in device then record computer playback using a cable to line-in? Does that skip at a given buffer setting under WASAPI, but not skip at the same buffer setting if you change host to Windows DirectSound or MME?
Presumably in most cases the "Defaults" button will be used in built-in effects where there will be no "Debug" button. If so then "D" is arguably the best choice as the access key for that button.Robert J. H. wrote:But it is annoying when your used to alt-d for years and now you always get that nice Little ping when pressing it.
You can e-mail Rob from the Nabble -devel list archive if you feel strongly about it. "F" would seem to be an alternative to "D" but not as good.
As far as I know, WxWidgets for the particular platform decides if ALT keys work with OK and Cancel. On Windows they don't, on Linux they do.Robert J. H. wrote:It would have been better if he had introduced a shortcut for the OK-button since enter is otherwise used in the Nyquist prompt.
Probably because manipulating Nyquist Prompt with the keyboard works differently on all three platforms, so it is very hard to describe. However since Nyquist Prompt had no text at all in the Manual, I have added some at http://manual.audacityteam.org/man/Nyquist_Prompt .Robert J. H. wrote: However, ctrl-enter works but this is nowhere documented.
On Mac, ALT key navigation is not supported, and tabbing between buttons is off by default. Tabbing on Mac can be enabled by opening the System Keyboard Preferences, choose the "Keyboard Shortcuts" tab, then under "Full Keyboard Access", choose the radio button "All controls".
Robert J. H.
It's arguable if it is better to Change an old button to a new hotkey or to introduce the new button from the start with a new one (alt-f).
Both combinations are easier to grab than alt-g (my fingers are a Little gouty with advancing Age and too much Rock 'n' Roll).
It may have the Advantage that the german Version will use the same hotkeys as the english one:
Debug / Diagnose
Defaults / Standard
However, there are dozens of other languages.
And I've given up to use the german Version because the hotkeys of the effect menu do not work properly (if an integrated effect has the same letter as an Nyquist plug-in).
I'll post back when I've tested the latency properties further.
Debug / Diagnose
Defaults / Standard
- Quality Assurance
I am guessing you don't mean effects shortcuts that you can set in Keyboard Preferences, but navigation keys you press after ALT?Robert J. H. wrote:And I've given up to use the german Version because the hotkeys of the effect menu do not work properly (if an integrated effect has the same letter as an Nyquist plug-in).
This seems to have happened because the German translator chose to use access (underline) keys for the built in effects. We decided long ago not to do this because of the large number of built-in effects in the menu and the large number of effects that the user could theoretically add themselves.
Not using access keys means that you can effectively seek by initial letter of the item then press ENTER when you find the item you want.
Using an access key means that the item opens if you type its key assuming that two items do not have the same access key, blocking access to effects underneath the divider that cannot have access keys.
I'll remove the access keys from the German translation for Generate, Effect and Analyze.
Robert J. H.
Thank you very much Gayle, that's exactly the Problem. Now back to WASAPI:
Sadly enough, the Audio buffer increase Fails to prevent from skipping when recording with WASAPI.
The jump occurs at 2.00 s, no matter if line-in or loop-back is used.
It's also astonishing that the Audio buffer can be set to 0 MS - No difference in the Sound Quality after those 2 s.
It is obvious that the Audio buffer is automatically regulated when working with WASAPI.
With MMe and WDS there's (nearly) no playback of course with 0 ms buffer size.
