Recording voice for 2-day workshop
JuneBugger
Re: Recording voice for 2-day workshop
Got it. Thanks so much! June
- Quality Assurance
An exported 16-bit mono WAV at 44100 Hz sample rate takes 5 MB per minute. So 200 minutes is about 1000 MB (about 1 GB). The limit for WAV is 4 GB but you should not go above 2 GB for WAV because older media players or older versions of Windows will not support WAV files greater than 2 GB.kozikowski wrote:Someone will correct me, but I get around 100MB for 200 minutes in mono, so I don't think you're likely to run out.
The Manual has some information about file sizes:
http://manual.audacityteam.org/o/man/fi ... ml#compare .
JuneBugger
Dear Koz:
Just to let you know that the recording turned out great. Thanks again.
June
June
