Audacity lowering my volume
daveaudacity01
I own a windows 7 and every time open audacity my volume lowers. Sometimes when I do other tasks on audacity like switch microphones. My volume lowers. Why is this?
Re: Audacity lowering my volume
If the software you use has hooks into the operating system, then the last thing you open takes over. Try pushing the Audacity Playback volume control all the way up. The slider next to the speaker.
- Quality Assurance
Look at Help > About Audacity. Do you have version 2.0.3? If not, try that version:
http://audacityteam.org/download/windows .
