How can I get output clearly
delta
Post by delta » Tue Apr 23, 2013 8:33 am
I have recorded in Audacity through my laptop connected with mixer is not clear. Once I record it was clearly recording.
The recorded output was not clear after I play. Is there facilities in Audacity to increase sound and things to listen clearly?
Re: How can I get output clearly
Post by kozikowski » Tue Apr 23, 2013 4:31 pm
Does it sound bubbly or fade out?
http://manual.audacityteam.org/o/man/fa ... hancements
If your problem is very loud sound with crunchy distortion, it's possible you plugged the mixer into the Mic-In of your laptop. Many laptops do not have Stereo Line-In. Mic-In is mono and overloads very easily.
http://www.kozco.com/tech/audacity/pix/ ... pSound.jpg
We recommend the UCA202 as one good way to add stereo recording to your laptop.
http://www.kozco.com/tech/audacity/pix/ ... Lenovo.jpg
