Clicks when using "change tempo" effect
worth1000pictures
Post by worth1000pictures » Mon Apr 22, 2013 1:15 am
I have a recording of an acapella choir. The tempo shifts over the course of the song and I'd like to match it to a beat.
'Change tempo' does the job, but I'm getting a click at the beginning and end of each section I change.
Help?
Vista Home Prem
.exe installer
Re: Clicks when using "change tempo" effect
Post by steve » Mon Apr 22, 2013 9:51 am
If possible, ensure that the start and end of the selection are at moments of silence (or near silence). Because the audio is being stretched the stretched waveform is unlikely to match up exactly with the original waveform, and thus cause a click.
Note also that the "Sliding Time Scale / Pitch Shift" effect is a more advanced "stretching" effect that will usually give better sound quality than the more simple "Change Tempo" or "Change Pitch" effects: http://manual.audacityteam.org/o/man/sl ... shift.html
Also, the "Sliding Time Scale / Pitch Shift" usually manages to avoid clicks at the start, so you only need to worry about getting the end of the selection click free.
worth1000pictures
Post by worth1000pictures » Mon Apr 29, 2013 12:41 am
Thanks! That helps.
Whole phrases are easy to work with, and in spots where I need to adjust just part of a phrase, I'm using the 'generate silence' function to make a tiny space, adjusting the tempo as needed, then deleting the silence and using the 'draw' function to tidy it up.
