Can't turn off playback
dansve
Post by dansve » Sun Apr 21, 2013 2:13 pm
Audacity 2.0.3
Windows 7 Ultimate 64bit
Hello, this is my first post and i'm not even sure if this is the right forum section so correct me if i'm wrong.
I have a Shure SM58 microphone (wireless) and a imultimix 8 USB mixer and they seem to work fine.
But when i try to record anything, say i put the beat (instrumental) into audacity, and i record my voice while playing it, it seems the music is recorded too.
Also when i'm recording just my voice, it also records all background sounds and system sounds.
This doesn't happen when i record with a regular PC mic.
So i guess it's somekind of playback from the mic/mixer ?
Can anyone help :/ i've searched in ALL the options, and i'm at a really dead end.
A friend said it's because my microphone is wireless and that's why there are no playback options for it on the sound tools.
Re: Can't turn off playback
Post by kozikowski » Mon Apr 22, 2013 8:24 pm
You're recording the wrong thing. Audacity > Edit > Preferences > Devices > Recording > Device. You should be recording your USB device, not Stereo-Mix, Internal Microphone, or anything else. "USB Sound Device" or something like that? It may not say the name of your mixer.
Also, Audacity > Edit > Preferences > Recording Select [X] Overdubbing and deselect [_] Playthrough.
http://manual.audacityteam.org/o/man/tu ... rdubs.html
dansve
Post by dansve » Wed Apr 24, 2013 11:09 pm
kozikowski wrote:You're recording the wrong thing. Audacity > Edit > Preferences > Devices > Recording > Device. You should be recording your USB device, not Stereo-Mix, Internal Microphone, or anything else. "USB Sound Device" or something like that? It may not say the name of your mixer.
I am recording with the microphone driver of the Shure SM58, sterio-mix is off in volume options. i disabled it in total.
Post by Gale Andrews » Thu Apr 25, 2013 7:17 am
What is your playback device in Audacity Device Toolbar?
If it's the mixer then you must have the mixer set up to send what you are hearing back to Audacity to be recorded.
dansve
Post by dansve » Thu Apr 25, 2013 2:54 pm
I am using the mixer's microphone USB driver, and the USB driver for speakers. i've tried using everything. there is just no playback option ANYWHERE.
Here is how i got things cabled up. maybe there is a playback on the mixer that i don't see.
Post by steve » Thu Apr 25, 2013 3:31 pm
This is the bit that Koz was asking for:
dansve wrote:I have a Shure SM58 microphone (wireless) and a imultimix 8 USB mixer
So have I got this right?
The microphone connects wireless to a receiver.
The receiver plugs into the imultimix (channel 1).
The imultimix connects to the computer via USB.
Your headphones / speakers are connected ????
If so, the problem would seem to be a setting in the imultmix. The microphone and the computer playback are being mixed in the imultimix and sent back to Audacity for recording.
dansve
Post by dansve » Thu Apr 25, 2013 4:46 pm
steve wrote:This is the bit that Koz was asking for:
Yes, but i have cheaked everywhere and there is no playback options anywhere.
Post by steve » Thu Apr 25, 2013 4:52 pm
How are you monitoring (listening while recording)?
dansve
Post by dansve » Thu Apr 25, 2013 9:03 pm
steve wrote:How are you monitoring (listening while recording)?
I've tried listening while recording, i've tried turning without listening. it's all the same o_o
dansve
Post by dansve » Thu Apr 25, 2013 9:20 pm
It seems to record everything. the only way to record my voice only is to either only record vocal, or put on a song, put Output Volume on the most left and then record. but then i don't hear the music.
