What effects are used here?
ScheifferKBates
Hi guys, I'm new here.
Just wondering can somebody give me a detailed run down on what effects are used to create this sort of Demonic voice? Preferably something that sounds almost exactly like this. Mostly all I've heard off other people is "Apply a lot of Echo" but that just doesn't sound right to me.
http://www.youtube.com/watch?v=GJa7JV_QCzI
Thanks guys
Thanks guys
Re: What effects are used here?
Reverse Reverb.
Reverse the track, add some reverb, then reverse it back the right way again.
Cool trick to remember... I welcome hearing creative ways to make monster voices in fantasy novels.
ScheifferKBates
Thanks alot Steve!steve wrote:Reverse Reverb.
ScheifferKBates
Sorry to bump up this thread, but I'm wondering if somebody can help me with identifying the values of GVerb for this? I seem to keep getting too much echo, I'm just wondering if somebody could open up their Audacity and see if they can get something sounding similar..
ScheifferKBates
I seem to be getting too much of the "hall effect" when I reverb it myself, I'm wondering what I can do to make it sound more like the link above
Try setting:
Change Pitch:
-4 semitones
Echo:
Delay: 0.04
Factor: 0.25
Reverse
GVerb
Room Size: about 100
Reverb time: about 0.5 second
Damping: 0.5
Input Bandwidth: 0.75
Dry signal: -3
Early reflection: -20
Tail level: -12
Reverse
Change Pitch:
-2 semitones
Not quite the same, but still quite demonic.
Change Pitch:
-4 semitones
Echo:
Delay: 0.04
Factor: 0.25
Reverse
GVerb
Damping: 0.5
Dry signal: -3
Tail level: -12
Reverse
Change Pitch:
-2 semitones
ScheifferKBates
Thanks, stilll a little bit too much "hall effect" but it sounds more a like than it previously didsteve wrote:Try setting:
Change Pitch:
-4 semitones
Echo:
Delay: 0.04
Factor: 0.25
Reverse
GVerb
Damping: 0.5
Dry signal: -3
Tail level: -12
Reverse
Change Pitch:
-2 semitones
You need to play with the effects. I put together that sample is a couple of minutes and spent much longer typing up the instructions to give you an idea of the kind of things you need to be trying.ScheifferKBates wrote:Thanks, stilll a little bit too much "hall effect" but it sounds more a like than it previously did
ScheifferKBates
Yea thanks for that. I've managed to get the effect now, thanks Steve.steve wrote:You need to play with the effects. I put together that sample is a couple of minutes and spent much longer typing up the instructions to give you an idea of the kind of things you need to be trying.ScheifferKBates wrote:Thanks, stilll a little bit too much "hall effect" but it sounds more a like than it previously did
