http://manual.audacityteam.org/man/Tuto ... _Recording
Code: Select all
Click on the downward pointing arrow beside the microphone symbol under the recording VU meters and select "Start Monitoring".Code: Select all
Talk or play at a normal volume and watch the red recording VU meter.Code: Select all
Adjust the recording volume with the right-hand Input Volume Slider (by the microphone symbol).Code: Select all
If clipping occurred turn down the recording level a bit and try again. Thanks for any answers. It's kind of confusing, sort of like someone assumes I know everything already.
