can you set to record only when input is given?
supercooldude
Post by supercooldude » Thu Apr 11, 2013 7:22 pm
Like "spy mode" in some other recording software that is limited?
Re: can you set to record only when input is given?
Post by kozikowski » Thu Apr 11, 2013 8:06 pm
Audacity has "Sound Activated Recording."
Edit > Preferences > Recording > Sound Activated...
supercooldude
Post by supercooldude » Thu Apr 11, 2013 9:19 pm
kozikowski wrote:Audacity has "Sound Activated Recording."
Thanks
I just downloaded it, and all of the settings and available info online can be overwhelming until I learn the software better. You saved me a good deal of time and stress. This software is pretty sweet! I will cherish it always.
