Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Fri Apr 12, 2013 4:44 am
Device Toolbar is where you were choosing Audio Host, output and input device and recording channels in Audacity:
Do not change Device Toolbar settings if it is now working, but if you have hidden Device Toolbar and you need to show it, choose View > Toolbars and click on Device Toolbar.
jacobix398
Post
by jacobix398 » Fri Apr 12, 2013 3:11 pm
Thanks again,
When I Click on view and then toolbars and then device toolbars I seem to have all checked
at that location,but I don't get the interface of the toolbar.
If I uncheck all but device toolbar I still don't get the image of toolbar.
It's probably nothing I need but can't help wondering why it don' show.
- Quality Assurance
Post
by Gale Andrews » Fri Apr 12, 2013 10:41 pm
You may have moved Device Toolbar somewhere you cannot see it.
Try View > Toolbars > Reset Toolbars then all toolbars should dock into position.
jacobix398
Post
by jacobix398 » Fri Apr 12, 2013 11:30 pm
I guess I'm giving up on finding the image of the toolbar. It's just not working.
- Quality Assurance
Post
by Gale Andrews » Sat Apr 13, 2013 8:44 pm
If it's easier for you and you need to change input or output or recording channels, Edit > Preferences then choose "Devices" top left. Those are the same choices that are in Device Toolbar.
jacobix398
Post
by jacobix398 » Sun Apr 14, 2013 4:32 am
Yes,thanks.That will work ok for me.
