I write a simple .ny file in plugs-in , but it doesn't exist in audicity interface when running.
The content of file :
;nyquist plug-in
;version 2
;type process
;categories "http://lv2plug.in/ns/lv2core#MixerPlugin"
;name "Mytest..."
;action "Mytest..."
(mult (ramp) s)
Why?
Why my nyquist example count not execute?
Robert J. H.
Re: Why my nyquist example count not execute?
I can't see a fault at first glance.
- Maybe you have used "forbidden" characters in your file name.
- Or you haven't restarted Audacity
- Or the Text format is not ANSI.
- Or the file extension is hidden and would be in fact "mytest.ny.txt".
What says the log file? You'll find it under help, last entry "Show log"
If it is a text/character format problem, it will be most probably be listed.
The contents look OK.
Please attach the actual file (use the "Upload attachments" option below the message composing box).
