Lost Project
Re: Lost Project
Post by Gale Andrews » Thu Mar 28, 2013 8:23 am
kozikowski wrote:Leaving an unsaved or unexported show open while you go shopping is a very bad idea. If anything at all happens to the machine or any of the parts that Audacity is standing on, the show goes straight into the dustbin.
Not really. If the cat pulls the plug out while you are gone, Automatic Crash Recovery should work. The autosave file should recover unsaved changes to either saved projects or to projects that were never saved.
If you close the project normally then the autosave file is deleted.
Bob, if you Edit > Preferences then look at "Directories" what exactly is the location of the temp directory? Select and copy the location from the text box and paste it in here. If it's a truncated short name, it might be the explanation, in which case you should try the "Choose..." button and try selecting a suitable directory.
rj7500
Re: Lost Project
Post by rj7500 » Thu Mar 28, 2013 12:11 pm
Hi Gale
This is the directory I found in the preferences section of Audacity
C:DOCUME~1BOBHEN~1LOCALS~1Tempaudacity_1_2_temp
Re: Lost Project
Post by Gale Andrews » Fri Mar 29, 2013 4:26 am
rj7500 wrote:This is the directory I found in the preferences section of Audacity
Hi Bob,
Yes that's what I meant by a "truncated name":
http://en.wikipedia.org/wiki/8.3_filename .
Later Audacity can lose access to the temp folder if it has the short name inherited from older Audacity. I think that is what happened to you.
Did you try the "Choose..." button in Directories Preferences and selecting another temp directory? I'm not sure on XP, but I think if you do that the file path will appear in the Directories Preferences with a full name, and you should not have another problem.
Re: Lost Project
Post by kozikowski » Fri Mar 29, 2013 5:27 am
No, I don't mean anything straightforward like that. I mean you get back from the Tesco and the screen is partially unresponsive or having any one of a number of "pre-crash" symptoms. Or Audacity just isn't on the screen any more.
Re: Lost Project
Post by Gale Andrews » Sat Mar 30, 2013 6:15 am
Does that happen more than occasionally? If so, on what operating systems?
Do you have a better chance if you are standing there when it happens?
rj7500
Re: Lost Project
Post by rj7500 » Sat Mar 30, 2013 1:33 pm
Not sure what you're asking Gale but........
It was a one time occurence and most likely my own fault. Your suggestion about naming and saving a project at the very start is a wise one and one which I will do from now on.
Thanks to the team for all your help now and in the past.
Bob H
Re: Lost Project
Post by Gale Andrews » Sun Mar 31, 2013 6:58 am
I mean the temp directory name with the ~1 in the names is probably the problem, but if you always save a project by choosing the folder (so avoiding the temp directory) it's also a solution.
rj7500
Re: Lost Project
Post by rj7500 » Tue Apr 02, 2013 5:21 pm
Help guys......same project another problem
I managed to re record, edit and proof this project. I saved it but when I try to open it I get the 'Audacity does not recognize this file message. I named it properly and I have both the aup and data files saved.
Bob H
Re: Lost Project
Post by Gale Andrews » Wed Apr 03, 2013 6:15 am
rj7500 wrote:Help guys......same project another problem
If you are using File > Import Audio or dragging in the AUP file, try File > Open instead.
If that does not help, please attach the AUP file.
