Contrast tool in Analyze stops working after closing project
Paul L
Post by Paul L » Mon Mar 18, 2013 10:01 pm
Problem seen in 2.0.2 and 2.0.3, don't know about earlier.
1 Open more than one project.
2 Use Analyze, Contrast in one of them, selecting anything.
3 Then close that project.
4 Then use Analyze, Contract in the other. The dialog does not come up. Seems I must restart Audacity to make it work again.
Step 2 seems necessary to reproducing the problem.
Re: Contrast tool in Analyze stops working after closing pro
Post by steve » Mon Mar 18, 2013 10:21 pm
I don't seem to be able to reproduce that problem.
Are you leaving the Contrast window open when you close the project? If so, are you sure that the contrast window is not hidden behind another window?
Paul L
Post by Paul L » Mon Mar 18, 2013 10:46 pm
I'm sure I'm closing the contrast window before closing the project.
