analog High resolution output and recording?
Re: analog High resolution output and recording?
Post by Gale Andrews » Sun Mar 17, 2013 1:33 am
ragnar.jensen wrote:
DVDdoug wrote: I've "heard" that Windows re-samples everything to 48kHz...
Windows doesn't do that, but many sound cards do.
My understanding is that specifically, the Windows MME API resamples everything to 44100 Hz
http://wiki.audacityteam.org/wiki/Multi ... Interfaces .
ragnar.jensen
Post by ragnar.jensen » Sun Mar 17, 2013 6:43 am
I found this notice over at the JRiver Wiki
"The only way to prevent a Creative Labs X-Fi based card or Asus Xonar card from resampling all incoming audio is to use ASIO and the driver that came with the card. With these cards, WASAPI exclusive will not change the master clock of the card"
Ragnar
ragnar.jensen
Post by ragnar.jensen » Sun Mar 17, 2013 6:49 am
Gale Andrews wrote: My understanding is that specifically, the Windows MME API resamples everything to 44100 Hz
Yes, that's correct. I missed that.
Ragnar
