Audacity Will Only Record Left Channel
elvisjock
Post by elvisjock » Mon Mar 04, 2013 1:15 am
I've been using Audacity for several weeks, with no issues until today.
I connect a Mackie console to the computer. On recordings made today, I was hearing droputs. After a bit of troubleshooting, I elected to reinstall Audacity.
I'm not hearing any further dropouts, but I am noticing that it is only recording left channel. I hear stereo from the Mackie. I see stereo on the Mackie VU meters. I hear left channel only on playback. I tried several remedies I found in the FAQ here, but nothing has helped.
Running Windows 7. All things remain equal, except the reinstall on the software.
Appreciate any suggestions!
Re: Audacity Will Only Record Left Channel
Post by kozikowski » Mon Mar 04, 2013 4:06 am
How? Exactly. RCA to 1/8" stereo adapter like this?
http://kozco.com/tech/audacity/pix/RCAMiniStereo.jpg
Did you plug it into the Mic-In of your laptop?
Are you seeing stereo while Audacity is recording like this:
http://kozco.com/tech/audacity/Audacity1_record.jpg
Or is there only a single line of blue waves?
Which Audacity? On Windows I think it's Help > About.
