Stereo to mono
terryondixie
Stereo to mono
Post by terryondixie » Fri Feb 01, 2013 6:57 pm
Is it possible to alter stereo music to mono?
The score is much longer than I need; how do I shorten the playing time?
Thanks
Re: Stereo to mono
Post by Gale Andrews » Fri Feb 01, 2013 7:46 pm
terryondixie wrote:Is it possible to alter stereo music to mono?
Select the track then Tracks > Stereo Track to Mono.
terryondixie wrote:The score is much longer than I need; how do I shorten the playing time?
Edit > Remove Audio or Labels > Delete the parts you don't want.
Or Edit > Remove Audio or Labels > Trim Audio the part you want to keep. See http://manual.audacityteam.org/o/man/tu ... _file.html .
