Settings help
Neilkhess
Settings help
Post by Neilkhess » Thu Jan 31, 2013 2:24 am
I am trying to record a message for a phone system and I need the following settings for the audio file.
Bit Rate: 64kbps
Audio Sample Size: 8 bit
Channels: 1 (mono)
Audio sample rate: 8 khz
Audio Format: CCITT u-Law
Could someone help me out with figuring out how to do this?
Thanks!
Neil
Re: Settings help
Post by kozikowski » Thu Jan 31, 2013 2:40 am
I don't see those settings in normal Audacity Export, so you probably need the FFMpeg software.
http://manual.audacityteam.org/index.ph ... tallffmpeg
Re: Settings help
Post by Gale Andrews » Wed Apr 29, 2015 10:56 pm
kozikowski wrote:I don't see those settings in normal Audacity Export, so you probably need the FFMpeg software.
FFmpeg is not required. See http://forum.audacityteam.org/viewtopic ... 49#p274349.
