Recording from decks to laptop!
mickiep89
Post by mickiep89 » Wed Jan 30, 2013 5:29 pm
I am struggling to record from my decks to my laptop. I have a jack lead coming from my master socket on my mixer into a soundcard and have tried every combination from the drop down menus and looked through the help manual on the website. The closest i have come to getting any sound is a static sound. I'm not sure if the soundcard is rubbish as when i tried to change it to the 2-channel 16-bit, there wasn't this option. Any help would be much appreciated!!
DVDdoug
Forum Crew
Re: Recording from decks to laptop!
Post by DVDdoug » Wed Jan 30, 2013 8:45 pm
You should be able to get some sound, but the mic-input on your laptop is wrong for the mic-input on your laptop. :( Unless your laptop has a line-input, you need an external interface. The Berhinger UCA202 is usually the lowest cost solution. There are all kinds of higher-end audio interfaces with various input options, but most regular "USB soundcards" are like laptops, with only mic-in and headphone out.
mickiep89
Post by mickiep89 » Thu Jan 31, 2013 8:25 pm
Cheers for the reply, i will try that out! Thanks :)
