Program reconfigures input
Weasel
Post by Weasel » Fri Jan 25, 2013 8:08 pm
I've used Audacity for several years now, but just recently ran into a new problem. When recording from any source, the program reconfigured the input so as to reproduce in a muffled, almost truncated sound, although the tempo is not compromised. Notice in the image below how the wave form is quite narrow. I have even uninstalled and reinstalled the program several times, but to no avail: even the newly installed version, 2.0.2, fails to record/reproduce correctly.
Re: Program reconfigures input
Post by Gale Andrews » Fri Jan 25, 2013 9:27 pm
Try turning off Windows and sound card sound effects and enhancements:
http://manual.audacityteam.org/o/man/fa ... hancements .
