MP3 option doesn't show up in file menu
flyingdolphin
How do I make a MP3? The MP3 option doesn't show up in the file menu. Where do I find it?
Re: MP3 option doesn't show up in file menu
Download and install the LAME MP3 encoder from this page.
Instructions for installing LAME are here: http://manual.audacityteam.org/o/man/fa ... .html#lame
Once you have LAME installed you will be able to export as MP3 by selecting "File menu > Export" and then select MP3 as the file format in the export dialogue screen.
