Trouble opening MP3 file into Audacity to edit it
Re: Trouble opening MP3 file into Audacity to edit it
Can you import this file?
- Attachments
- chirp.mp3
- (157.14 KiB) Downloaded 42 times
hjanderson
I downloaded chirp file, but could not import it....I I got was a flat line, no wave form. Other advice?
Try this as a test:
1) Open Audacity
2) File menu > Save Project As... and save the (empty) project.
Now try importing the chirp.mp3 file.
1) Open Audacity
